BIG problems...please help
Old Apr 8, 2001 | 07:55 PM
EROCK's Avatar
Guys, I got to the track on saturdaynd went to run and before I got to the starting line, the car spit and sputtered and just stopped. They pushed it to the pits and I checked the plug gaps and they were ok. I then got to the line on the next pass and when the lights came down I mashed it and from then on even now there is like a 2-3 SECOND hesitation. 2-3 SECONDS!!!! What is the problem? I run 93 or 94 gas like I have for the last 3 years. I put on a new cap, rotor, plugs, wires, and still a 2-3 second pause. When it quits bogging and catches it will rip your head off. The oxygen sensor was changed less than a year ago when the headers went on. I got a bosch so I think it should be ok. (theroeticly) All the sensors check out in the shop with proper readings and the fuel pressure is also the correct psi. Any suggestions? Please help guys. I am SO screwed. It is my only car.
Eric
p.s. 305 TBI
Teal 1991 Camaro R.S., T-Tops,
Leather, Re-worked 700r4 also w/kit,
MSD ignition, MSD 8.5 mm. superconductor wires,
MSD Coil, ADS superchip, Open element air cleaner,
K-n-N filter, Gutted cat, Flowmaster cat-back system,
Edelbrock TES headers, March 3piece billet underdrive pulleys
3.73 gears
http://www.geocities.com/gitarz2/camaro.html
I was shocked to see that companies sold a taillight
set for a rustang! Since when do they have taillights????
Old Apr 8, 2001 | 08:17 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Perhaps ignition module? Have you check the fuel filter in awhile. Man,it could be so many things.
Double check the timing and TPS.
Let us know.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Apr 8, 2001 | 10:01 PM
EROCK's Avatar
I know. I hate the fact that it could be so many things. Too muck can go wrong to cause this and they get pretty costly to keep guessing. Is my fuel filter in the tank with the pump?
Eric
Old Apr 8, 2001 | 10:15 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Your fuel filter is under the car on the driver's side, just in front of the rear axle. 10 minutes tops to change it out.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 8, 2001 | 11:38 PM
Macgyver's Avatar
This might sound crazy, but are you using a 14x3 air filter?
I heard once that on the auto cars, the 14x3 filter is so big that it can take a bit for the air to get moving inside the filter.
I think it sounds like BS, but crap, there's a last resort option for ya
Old Apr 9, 2001 | 09:54 PM
EROCK's Avatar
Mac,
I thought that I heard that also so for the last ditch effort to fix it, I have been running with NO filter. Didn't help so I put it back on. I just noticed that I have a broken sensor under the passenger side header. I just found out that it is for my fan. I am hoping that maybe the computer can't find this sensor and so it is running lean or it is in limp home mode. This may be the cause of my problem. I am hoping that once I fix this in the morning that the problem will be solved.
Eric
P.S. How do I get hte computer out of limp home mode if in fact that is what it is?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
