The difference between SBC and BBC ???
Old Jun 28, 2004 | 12:09 PM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Transmission: 700 R4
I need a little schooling concerning the difference between the SBC and BBC motors. I've read articles about 427 cu in. SBC's . My question is what determins the difference between the two ? I thought it was cubic inches. I understand about the stroked SBC's that gain cubic inches, but what are the determining factors that seperate the two ? I hope these are'nt lame questions but I just wanted to know. Thanks !
Old Jun 28, 2004 | 12:25 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The engines are to completely different designs. Every part is different. Its kinda like the difference between a inline 6 and a v6. Meaning that they are just different engine. A BBC is a BBC and a SBC is a SBC. It doesn't matter what cubic inches they are, because with aftermarket SBC blocks people can build more then 454cid SBC engines.
I hope this helps. Also go search the internet for BBC and SBC and see what you find.
Old Jun 28, 2004 | 01:24 PM
ede's Avatar
ede
differance would be the blocks used to build the engine, not the displacement
Old Jun 28, 2004 | 01:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The lifters are the same.
Old Jun 28, 2004 | 02:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
And the distributors.
Old Jun 28, 2004 | 03:48 PM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Thanks for the replys. I understand that they are different blocks.........but, was the big block actually made for heavier duty use, such as large trucks that needed the power capacity ? Or did Chevy just decide on a different engine design ? I understand that the SBC motor can also be designed for heavy-duty use. I was just wondering if anyone had a little bit of history concerning the comparison between the two or where to look for the history. I've seen and read the history of the 350 but cant find much on the big blocks. appreciate any direction or comments. Thanks !
Old Jun 28, 2004 | 05:27 PM
Marc 85Z28's Avatar
Basically the larger block allowed for more cubes without sacrificing durability. And you can't just look at it as a block vs block thing. The biggest advantage to the BBC is the canted valve design of the heads with the large ports.
Can't find info on the BBC?????????????? Open your eyes man! It's not like it's hard to find. There an immensely popular engine...
BAMiller
Sep 14, 2015 06:38 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
greenyone
Sep 2, 2015 03:39 PM
