dizzy out 180 and still runs??
Old Jun 28, 2004 | 08:33 PM
krusty's Avatar
Car: 89 GTA
Axle/Gears: Borg&Warner 3.27
Check this out. So, I'm trying to figure out my no start when hot. Testing everything I can before I start throwing parts at it. Pulled the cap to check pickup and to clean the module. Put it all back together and figure I'd check the wires (in case a couple were mixed up). Trace #1 back to the cap and it's where #6 should be. WTF?? Check it a couple more times and sure enough it is at #6. The firing order is correct and it does run strong when cold. The timing checked out at 6* with EST disconnected. Is this possible??? I haven't been drinking........ yet. When I swapped out the cap I just went wire for wire. Guess i should pay closer attention.
Old Jun 28, 2004 | 08:46 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Yea, so long as you know what piston is at TDC you can put your wires accordingly anywhere you want so long as the firing order remains the same.
Old Jun 28, 2004 | 08:49 PM
krusty's Avatar
Car: 89 GTA
So I should leave it like this? Will it affect the advance? or anything else?
Old Jun 28, 2004 | 09:27 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The way you describe will work just fine. It will have no effect on the advance whatsoever. The only problems you can have when this happens is the wires wont all be long enuf to get to the cap, but yours seem to be long enuf to make it work.
Old Jul 16, 2004 | 11:35 PM
Joshua Bennett's Avatar
Car: 1988 Chevrolet Camaro Iroc Z28
Engine: 5.7 liter TPI L98
Transmission: TH- 400
if you were 180 out could you just reverse the wires on the cap and be alright
Old Jul 17, 2004 | 01:47 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by Red Devil
...so long as you know what piston is at TDC you can put your wires accordingly anywhere you want so long as the firing order remains the same.
eightsixseven
Dec 16, 2024 01:50 PM
junkcltr
Aug 2, 2019 11:12 PM
italiano67
Dec 11, 2016 09:21 AM
cstrobel65
Aug 15, 2015 10:19 AM
92projectcamaro
Aug 6, 2015 01:20 PM
