What about this engine?
Old Apr 9, 2001 | 11:26 PM
jobryan26's Avatar
I posted before that I need a new engine. I'm still searching and found this one. What ya think? I think my Timing Chain is loose in my 305TPI(wore out with 151,000 miles). I want a 350 but can't afford a ZZ4.
http://www.goautocenter.com/300hp_tpi_1987-89.htm
'87 Trans Am:
(Engine)
305 TPI
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Kenwood Excelon
Old Apr 10, 2001 | 12:11 AM
FlashGTA
Guest
Posts: n/a
I don't like cast pistons.
Old Apr 10, 2001 | 01:26 AM
mtx28's Avatar
will second that
Old Apr 10, 2001 | 09:45 AM
jobryan26's Avatar
What's the difference? How would this effect me?
'87 Trans Am:
(Engine)
305 TPI
TB Bypass
Accel Super Coil
(Stereo)
Kenwood Excelon
Old Apr 10, 2001 | 11:22 AM
FlashGTA
Guest
Posts: n/a
Cast pistons are the cheapest pistons money can buy, other than used cast pistons. If you are going to spend all that money on a rebuilt engine then you should at least get hypereutectic pistons. You have different grade pistons, each one is a step up and are better, meaning they can take more abuse. Cast, Cast-Hypereutectic, Economy Forged (Speed-pro and TRW) and Premium Forged such as JE. You should get the best you can afford. If you plan on using it as a daily driver and never modifying it or putting nitrous or a supercharger on it then cast will work fine. But if you plan on upgrading it later, get better pistons and better rod bolts.
Old Apr 10, 2001 | 12:07 PM
jobryan26's Avatar
It will be a daily driver and I don't plan on using any NOS, Turbo, SuperCharger or etc. The only mods would be like basic bolt-ons like Exhaust, Plenum, Runners and etc. over time. What's up with vortech and non-vortech heads and intakes? What's mine? It's the stock intake (LB9) Any suggestions for a TPI 350 crate engine? Besides the ZZ4.
'87 Trans Am:
(Engine)
305 TPI
TB Bypass
Accel Super Coil
(Stereo)
Kenwood Excelon
Old Apr 10, 2001 | 12:37 PM
Bort62's Avatar
If your not too concerned with performance, the GM goodwrench 250 HP crate is a good choice.
250 Hp is alot for a daily driver anyway.
and No, You cannot use Vortech heads with TPI, yet...
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
