question on removal of that ac/heater box
Old Jun 28, 2004 | 10:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
you know the big black box im talking about? in the passenger side firewall? i decided its time to take it all out.. i got the top half out, and the heater core radiator-looking thing out.. so its now just the plastic shell and of coarse, the big hole in the firewall. question is.. i cant get the bottom part of that plastic shell off.. is their a bolt directly underneath it or something? and whats the easiest way to reach it?
Old Jun 28, 2004 | 11:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
When i took mine out, i utilized weapon "X." I swung the hammer at it and called it bad names. Came out REAL quick....in 1984623974 pieces.
Old Jun 28, 2004 | 11:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
hehehe thats what i was considering doing.. if all else fails..
Old Jun 28, 2004 | 11:33 PM
MNformula350's Avatar
I've done 2 now, the first one i did in my Formula with the motor in and therel a couple screws down where you can't really see them, the second one i did was in my Iroc with the motor removed, it made it alot easier.
Also there a 2 bolts you need to remove from the INSIDE of the car, behind the passenger dash under the carpet. and then the adhesive seal can be a little tough (back under the hood) i used a pry bar to break it loose.
hope that helps.
Old Jun 28, 2004 | 11:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i think i know one of the bolts u speak of.. i removed the nut from it on the engine side of the firewall.. the bolt is still sticking out though. thats one i bet your talking about.. on the far right.
now the second one.. i gues im just gonna pull hard and break it off.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
