Harmonic Dampner?
Old Apr 10, 2001 | 02:47 PM
Doug E's Avatar
Harmonic Dampner?
Ok, It has come to my attention that the dampner wobbles when the car is running. I believe this to be the cause of my shaking problems. So, what is involved in a harmonic Dampner installation? When my engine is just cruising below 2300 RPM,s it shakes real bad, but above that its fine. Anyway, anyone have some advice about the Harmonic Dampner?
Old Apr 10, 2001 | 03:06 PM
Doug E's Avatar
By the way, its an '86 305 engine.
Old Apr 10, 2001 | 03:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're definitely not supposed to wobble. They fail by the rubber strip in the middle giving out and then the outer ring can wander around and do whatever it wants to.
Just replace it.
You need a puller and an installer. Auto Zone, Kragen, etc. will "rent" you the tools. You could get another one at the junkyard (questionable) or get a new one from the dealer, or one from a racing place like Summit or Jegs or your local speed shop.
ICON Motorsports
Old Apr 10, 2001 | 04:40 PM
ede's Avatar
ede
basically all you have to do is remove the belt(s) and crank pulley, then remove the crank bolt. bolt up the puller and remove the dampner, use an install tool to press the replacement on with, bolt up the pulley and belt and you're all set.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Magman
Sep 13, 2015 12:14 AM
gixxer92
Sep 1, 2015 04:32 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
theshackle
Aug 22, 2015 06:52 PM
Christos
Feb 1, 2001 06:39 PM
