Stalls when put into gear
Old Jun 30, 2004 | 02:38 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Hey All,
This only happened twice however I fear it will get worse as time goes on. When I go from reverse to Drive sometimes my car will chug, RPM's will drop and the car stalls out. Like I said it only happened twice however it could be warning of something wearing out.
I was thinking maybe seeing how I haven't replaced the tranny fluid yet that this could be the issue...ether that or my Torque Converter
Old Jun 30, 2004 | 03:00 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
mine does this too periodicly
Old Jun 30, 2004 | 10:19 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
First two things that come to mind are vacuum leaks and a torque converter locking up prematurely.
Old Jun 30, 2004 | 10:25 PM
ThraxXx's Avatar
if its the torque converter would a tranny fluid swap fix that?
Old Jun 30, 2004 | 10:29 PM
dankhound's Avatar
Car: 91 RS
Possibly. If your fluid is in need of a change i would recommend changing it anyway. Unless it is black. IF its black its probably the only thing holding your trans together. Theres a 50/50 chance it will work after you pull the black stuff out.
Old Jul 1, 2004 | 01:51 AM
ThraxXx's Avatar
ok I will check that tomorrow when I have sunlight to work with...
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
mizz0313
Aug 12, 2015 06:45 AM
