Engine gets too hot after head swap
Old Jun 30, 2004 | 04:20 PM
SaiyajinXero's Avatar
Car: 94 G20 hi-top conversion van
Engine: 350 TBI
Axle/Gears: something vanny
Hi, I just did a head swap over the past 4 days in my 91 Camaro. Everything went well and the car is back on the road except now the temperature is WAY higher than it should be. It always stayed around 190 degrees and if it got higher the fan would kick in, now the fan turns on at around 240 degrees which is too hot in my opinion. I am thinking of just hooking up a switch and turning it on with that when I'm driving, but does anyone have any idea why it would do this? Where is the thermostat located? Is it in the heads and maybe thats why its different?
Old Jun 30, 2004 | 09:01 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
u swapped ur own heads but u dont know where the thermostat is?, its on the intake manifold.
Old Jun 30, 2004 | 09:44 PM
rezinn's Avatar
Yeah, that's kind of funny.
Do you mean to ask where the fan switch is? Passenger side head, frontmost sensor above/between spark plugs 2 and 4 IIRC.
Hope you used the right head gaskets. Don't let it overheat.
Old Jun 30, 2004 | 09:56 PM
Engine: 350 TBI
I had a friend help me swap the heads, so now I know how to do it too. The sensors on the side of the head are plugged in. I don't remember any switch between 2 and 4 spark plugs. But there is a sensor between 6 and 8. It's got full coolant and full oil, its all circulating and working good. I'll just hook up a switch to the fan so its on whenever I'm driving, thatll be a lot healthier for the engine anyway. Thanks for the replies
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
