Vibration started up
Old Jun 30, 2004 | 04:46 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
Ill start at the begining, I have an 88 GTA now and since have been doing some work to it to fix it up. I noticed that the trans mount was torn and was causing some harsh thuds under the car so I decided to replace it with an Energy suspension piece. I got the car all back together and on the test drive to make sure it was ok I noticed its now vibrating when the engine hits about 2k rpm and then again at around 4k and up to redline. I was wondering what could be causing this vibration in the engine and/or what I can do to make it go away. I knmow its engine related because it even does it sitting still when I free rev the engine to these RPM ranges.
Old Jun 30, 2004 | 08:31 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
I had a similar problem and in the end it turned out that the new transmission bushing slightly changed my pinion angle.
The vibration would start around 60 mph, ~2000 and just get harsher the faster you went. At 80mph and above on the freeway it was just awful.
Old Jun 30, 2004 | 08:42 PM
meridius's Avatar
I dont think its driveline related since when its doing it on the road I pop it in neutral it goes away when the RPMs drop and I can actually get it to vibrate when its sitting still and rev it up. I was thinking along the lines of harmonic balancer and since this mount is much more solid its not absorbing the vibration but I would like ot know where else to look and what all I should check for as well.
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
db057
Aug 22, 2015 08:17 PM
spaigo
Aug 21, 2015 07:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
