Gasket interchangeability
Old Apr 10, 2001 | 11:18 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I have the 87+up roller 350 block. I want to do a cam change. I was wondering which gaskets interchange between my engine and the pre-87 engines? Do the Intake and timing gaskets interchange? I know the valve cover ones don't but I've solved that problem. The reason I ask is because summit has a set for like 20 bucks and my local part store wants 40 bucks for all the gaskets.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box.
Old Apr 11, 2001 | 12:20 AM
Vader's Avatar
JDM,
The earlier style intake may have different bolt locations and retainer holes. By the time you supplement the "cheaper" set with all the correct gaskets, you'll have wasted all the savings you had from purchasing the "bargain" set.
Check with the GM dealer. They can be surprisingly inexpensive for such common things as gasket sets. The rebuild set for an LT1 at the GM dealer was $118.00, and over $200.00 for a Fel-Pro set.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
