Timing light acts "funny" when you attach the vacuum advance...
Old Jul 1, 2004 | 05:19 PM
Trevor K's Avatar
I check my timing without the vacuum advance, the light works as it should (It's a snap-on light BTW).
Once I hook up the vacuum advance light, the light acts all funny. It'll seem to "miss".
What could be causing this - the pickup coil being faulty?
Old Jul 1, 2004 | 06:12 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
What do you mean by the light will seem to miss... Does it kind of flicker instead of being a steady blink? Or are you just seeing the timing mark go all over the place?
Also what kind of light is it--the pickup that is? The old school kind you practically have to disable a cylinder to use...? Or is it an inductive pickup?
Old Jul 2, 2004 | 05:10 AM
ede's Avatar
ede
WAG the light works fine and so does the vacuum advance
Old Jul 2, 2004 | 09:05 AM
Trevor K's Avatar
What does "WAG" mean?
I think it's an inductive timing light made by Snap On...
Old Jul 2, 2004 | 09:35 AM
ede's Avatar
ede
wild *** guess
Ghettobird52
Jul 5, 2024 11:18 PM
Andrew6.688
Dec 13, 2015 10:59 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
