need help with ignition
Old Apr 9, 2001 | 09:36 PM
v6-3.1's Avatar
I have a 1990 camaro 3.1L V6. I only get 8 MPG. I did a tune up, no help . I want to adjust the ignition timing but I never did it, can someone tell me step by step how to do it?
Old Apr 9, 2001 | 10:03 PM
Vader's Avatar
V6,
If you did a "tune up" but didn't check the base timing, exactly what steps did you perform?
A "tune up" for an FI engine should include the following:
1. Cooling system inspection;
2. Clean or replace spark plugs;
3. Ignition wire testing;
4. Distributor cap/rotor (if you don't have the OptiSpark);
5. PCV valve cleaning or replacement;
6. Air filter;
7. Cleaning the IAC;
8. Checking/setting TPS voltage;
9. Check/adjust minimum air rate;
10. Check/adjust timing;
11. Code scan.
Maybe you should go back and clean up a few missed items, then report back with the remaining problems. I'll bet there aren't too many.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 9, 2001 | 10:31 PM
v6-3.1's Avatar
can you please tell me how to do these??
Old Apr 10, 2001 | 10:05 AM
v6-3.1's Avatar
ttt
Old Apr 10, 2001 | 10:35 AM
IROCketZ28's Avatar
v6-3.1,
Check out the "Technical Articles" section of this site to get in depth lessons on your tuning questions!
** I'm not sure if the voltage specs are the same for the 6-shooter as they are for the V8s. Anybody know what voltage V6 TPSs should be set at?
'87 IROC Z28
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 800 watt stereo system
Grant wheel
Otherwise stock, & good for a 14.68 at DeSoto Dragstrip
More to come soon...
Shooting for high 13's with bolt-on's
Old Apr 10, 2001 | 07:08 PM
v6-3.1's Avatar
where is the aldl? what is a aldl ?
Old Apr 10, 2001 | 07:32 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Your ALDL (Assembly Line Diagnostic Link) is where you would either plug in a scanner or a paper clip to pull your trouble codes. It should be above your right knee when you sit in the driver's seat and might be covered with a little plastic piece. It is about 1" x3". You should really look through the tech articles section, it will explain how to pull the codes and what they mean.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
[This message has been edited by Kevin Irving (edited April 11, 2001).]
Old Apr 10, 2001 | 07:39 PM
v6-3.1's Avatar
thank you very much, now I know what that is, I pulled the codes before butI did not know what the name of it was. thank you for your time!!
Old Apr 10, 2001 | 08:00 PM
v6-3.1's Avatar
The tech article did not give an informative tutorial about the TPS.for the TPS(Throttle Positioning Switch) , can I use a regular voltometer (needle type), can someone give me more info? also is the IAC the same as the minimum air rate?
Old Apr 10, 2001 | 08:19 PM
v6-3.1's Avatar
I also read that the 90-92 TPS are self adjustable and do not need to be tampered with, is this true??
Old Apr 10, 2001 | 08:48 PM
v6-3.1's Avatar
to the top>>
Old Apr 10, 2001 | 09:50 PM
v6-3.1's Avatar
btt
Old Apr 11, 2001 | 07:10 AM
Car: 1985 Trans Am
Yes, the 90-92 TPS is not adjustable, it uses the voltage given when the throttle is closed as the base unless it is over 1.0v. I guess the tech article on how to adjust the TPS wouldn't apply to you then.....
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
