screw in studs on stock heads
Old Jul 4, 2004 | 09:25 PM
88Z's Avatar
88Z
Car: 88 Iroc
What do you have to do to be able to use screw in rocker arm studs on stock heads?
Old Jul 4, 2004 | 10:14 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Remove the pull out (pressed in, factory) studs and have them worked for screw in studs. Is this a repair stud or a performance screw in type? I believe performance screw in types require the stud boss to be milled.
Old Jul 5, 2004 | 06:10 AM
ede's Avatar
ede
remove the pull out studs, remove.4 off the stud boss, tap for screw in studs. i wouldn't use the repair studs over the preformance screw ins.
Old Jul 5, 2004 | 09:22 AM
Vader's Avatar
As indicated, the repair (collarless) studs are nowhere near as strong as the shouldered studs in terms of resistance to deflection. They will still be a lot better than the pressed studs for resistance to pull-out, however.
If you want a quick/dirty fix to lifting studs, the collarless type will work. If you are building heads and want to do it correctly, get shouldered studs, remove the heads, and mill the stud bosses flat. I've done both and had no problems. For a very aggressive cam and set of springs, the collarless type may not be up to the task. For a relatively mild street application and cam swap where you might not necessarily want to pull the heads, they are superior to pressed studs.
From my experience, if you plan to use floating rocker arms and guide plates, the stud bosses should be milled down about 0.400" from the theoretical deck, as ede explained. If you are not intending to use guide plates, you can mill about 0.260". I've had very good success using a piloted spot face cutter. You can jig the head level then whip out all eight holes in about five minutes.
An easy way to determine the deck is to measure the height of the existing studs as a reference for final depth.
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
transaero
Aug 31, 2015 01:14 AM
355tpipickup
Aug 25, 2015 12:54 AM
