Harmonic Balancers
Old Jul 5, 2004 | 10:06 AM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
Harmonic Balancers
My harmonic balancer just went. The rubber is gone. Now the outer part is spinning and making noise. Also my car isn't running good at all. My questions are; will it hurt the engine if I drive around for a few days with out it, and when replacing the old one how do I know where the balancer goes in? is there a mark on the inner piece that will tell me, so that I can put the new one in the same position?
Old Jul 5, 2004 | 10:14 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I wouldn't drive without the balancer.
There is a woodruff key in the crankshaft and a corresponding keyway in the balancer. This is what aligns the crank and the balancer, and furthermore, the balancers timing mark.
Old Jul 5, 2004 | 09:25 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
harmonic balancer
Yes you can do engine damage if you place strain on your motor (race it ) and your harmonics timing is all out of whack.
If your motor is stock get a stock replacement. they have a slotted key way with only one way to go and off use a lil oil or grease to help it slide on.
One thing you need to do is get a Harmonic balancer removal tool to get the old one off.
While you remove the old one BE SURE NOT TO STRIP THE THREADS IN THE CENTER OF YOUR CRANK OR YOU WILL BE SORRY.
If you do stip them you will not be able to pull your new harmonic balancer on.
Old Jul 5, 2004 | 09:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Pioneer makes a pretty decent factory replacement balancer. I have one on my Caprice (LG4).
Old Jul 5, 2004 | 09:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Crap, thats twice today...stupid posting thing...
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
