Oil pressure switch
Old Jul 5, 2004 | 10:26 AM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Oil pressure switch
I need your advise on removing the oil pressure switch. I bought the socket from AZ for $6, but it is too deep. I keep hitting the side of the firewall and can't get the socket over the switch. Is there a better tool/method to remove the switch?
Thanks!
Old Jul 6, 2004 | 11:36 AM
nsimmons's Avatar
cut the socket
Old Jul 6, 2004 | 11:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Where is the switch? Is it behind the distributor? If so, it's on a brass fitting, just turn that a little bit to re-orient the sending unit.
Old Jul 6, 2004 | 12:32 PM
hitman's Avatar
switch
is mounted just above the oil filter, on the side of the block. If I cut the socket, how will it reach the hex which is at the base of the switch? I tried to use a wrench, but there is not enough room to swing it around.
Old Jul 6, 2004 | 12:41 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
They make a socket just for those switches! Check with Napa, they cost about 16 bucks!
Old Jul 6, 2004 | 01:31 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I used a channel locks, but my motor was out. Don't know how much room you have under there. It wasn't in very tight.
Old Jul 7, 2004 | 01:48 AM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
Re: switch
If you can weld, cut the drive side off the socket, so you have a hexagonal tube open on both ends, and weld a handle on somewhere convenient. I had to make such a tool to change my plugs after headers.
If you can't weld, try some of those vice grips with rubber jaw covers. Just be gentle. Anyone know how fragile the sensor body is?
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
