Two questions
Old Jul 7, 2004 | 04:07 PM
Casey_Butt's Avatar
Two questions
1) How much valve lift are people comfortable with when using pinned rocker arm studs?
2) How do you fasten header wrap to headers?
Thanks.
Old Jul 8, 2004 | 04:24 AM
ede's Avatar
ede
1) none, pull out studs fail with stock cam lifts
2) i used tape
Old Jul 8, 2004 | 10:30 AM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
Re: Two questions
Just a quick heads up on header wrap from my experience. Header wrap will cause the headers to "sweat", resulting in premature rusting-out of the header's primary tubes.
It's best to 'if you can afford it' to get the headers "Jet-Hot" coated... OR just leave them alone, unless you can afford to buy and install headers every few years.
Old Jul 8, 2004 | 11:29 AM
ede's Avatar
ede
yeah i wouldn't use the wrap either but the only time i did i used some high temp tape and safety wire
Old Jul 8, 2004 | 11:56 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If they don't sweat, they retain moisture picked up from puddles or whatever. Basically, once they get waterlogged and soaked, it's over for your headers.
I agree with the above, get them coated and be happy.
Oh, to answer your first question, i don't go by lift. I go by the spring pressure that I'm using. And i don't pin studs. I go to screw in studs the second i upgrade the springs/cam.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
