What do you guys think of my cam choice?
Old Apr 11, 2001 | 02:00 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm getting a new cam and think I have one. I just want to run it by you first.
I have an 87 LB9 IROC with 700R4 so my stock cam is not brilliant.
I spoke to Willie who has the same car and he is using a crane compucam 2032 p#104224. The specs are:
Lift (1.5 rockers)----452/465
Lift (1.6 rockers)----482/496
Dur @ 50--------------214/220
LSA----------------------------112
What do you think? I'm wanting a good power increase over the stock cam and a good idle. Willie tells me that the idle is a little rough at first but smooths out when it warms up.
Another suggwestion has been the compcams CS 264H-R12 Part# 08-302-8.
The specs are practically identical:
INTAKE EXHAUST
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .480 .480
.006 TAPPET LIFT 264 274
VALVE TIMING OPEN CLOSE
AT .050 INT 3-BTDC 33 ABDC
EXH 46 BBDC 6-ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 108 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 210 220
LOBE LIFT .3200 .3200
LOBE SEPARATION 112
Also, i've been told to replace the lifters along with the cam, any suggestions?
Thanks for the help guys, I look forward to getting your advice.
Robert
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old Apr 11, 2001 | 02:47 AM
burnoutrpm's Avatar
forget the crane uchmm i use that word VERY lightly and get a good decent comp cam! they even have a tech dept. thats more than happy helping you to select the "perfect cam" for your setup. i did this and the resulkts were amazing... they were right on..dont mean to hack on crane..but, welll. they suck!! ive had 1 cam many lifters and 2 pushrods crumble go COMP cams you wont be dissapointed!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 12, 2001 | 01:57 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the info. I'll e-mail comp and see what they recommed. Anyone else have anything to say about it?
Rob
Old Apr 12, 2001 | 06:08 AM
Nitro Don's Avatar
Im curently using Comp Cam TPI cam
210/220 .533/.544(1.6 rockers) 114lsa
I pulled it last week and Im putting in Comp Cams TPI cam 230/244 .544/.576(1.6) 112 lsa
this is going to be a big cam for a 305
Nitro Don
Old Apr 12, 2001 | 06:34 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Hey Don are you going to be selling that cam that you pulled?
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 12, 2001 | 08:34 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Don, what was the idle like with that cam? Did you notice much of a difference in performance?
Robert
Old Apr 12, 2001 | 12:55 PM
Bort62's Avatar
Damn Nitro, Enouhg Cam For that 5.0 ?
What heads are you Running ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 12, 2001 | 02:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Of all the cams in this post, the Crane is the poorest choice IMHO. Still, it's a much better one than what's in there, and lots of people run it and like it.
For your stock valve train the Comp 264 is the best choice. It would definitely be worthwhile to change the valve springs at the same time, and lose the stamped sheet metal rockers. The Comp cast steel roller-tip ones in the 1.52 ratio would be the way to go.
ICON Motorsports
Old Apr 12, 2001 | 05:41 PM
Nitro Don's Avatar
The 210/220 cam had a nice idle to it.I wpouldn't call it lumpy though.
As for a performance increase over the stock cam,the springs for the WP heads were only good for about .500 lift,with less than 100 pounds of pressure,and I broke the tops of all the exhaust springs.Even with that,I ran a few 12.8-13.00 at 116 mph.Before the swap I ran a 12.4 at 109 mph,But the speed increased by 7 mph and I was falling on my face at 5000 RPM.I feel with the right springs I could have put it in the 11's.
Since I tore the heads down to be ported and have larger springs installed,I said what the Hell,pull the cam.
Which brings out more problems.At almost .580 lift I have the guides machined down for more clearance,and some other clearance issues,But I think 230/244 duration in a 305 is going to be a lumpy cam,which will be good for flowing that nitrous
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 14, 2015 08:25 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
