Simple skipping prob. quest.
Old Apr 11, 2001 | 05:29 PM
smithtc's Avatar
can a vacuum leak cause car to skip?
My car skips at odd times, but don't believe it skips at WOT. Haven't gotten dirty in searching for problem yet...just curious if vacuum hoses being busted (I have some) could cause this .
Gunmetal 89GTA T-Tops L98
700R4 with 3.27 gears, street tires
Best 60 ft: 1.996
Best 1/8th mile: 9.02 @ 76.5mph with 60' time of 2.14
With these mods: air filter, hypertech chip, 3" exhaust (no cat.)
Old Apr 12, 2001 | 10:21 PM
Vader's Avatar
SmithInc,
If by "skipping" you mean rough idle and missing, yes. A vacuum leak will cause a lean mixture on one or more cylinders. Lean operation can cause misfire, backfire, rough idle, unsteady and wandering idle speed, and a whole host of other problems.
Make sure the vacuum lines and hoses are intact and properly connected according to the VECI label under the hood. Also check the PCV valve and EGR valves - they are in essence "programmed" vacuum leaks that can cause similar problems if they are not operating correctly.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Zane Story
Oct 8, 2015 12:40 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
