How should I adjust wheel bearings???
Old Apr 14, 2001 | 08:27 AM
LottaBallsCamaro's Avatar
I have been told so many different ways, well not ways just tightness, that its crazy.
We are the future, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Apr 14, 2001 | 09:04 AM
Vader's Avatar
LBC,
After the bearings are packed and the spindle is reassembled, install and torque the hub nut to 18-20 ft/lb while rotating the spindle. This seats the bearings fully in the races and displaces excess grease. If you don't have a torque wrench, 18-20 ft/lb is about what a spark plug is torqued. Without turning or moving the spindle, loosen the nut to relax the pressure, then retighten by hand/fingers only. Align the lock with the hole in the spindle and install the pin. If the holes do not align, tighten only to the point where you can insert the pin.
Ditto on the opposite side.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 14, 2001 | 01:34 PM
Thank you!
Old Apr 14, 2001 | 06:24 PM
GOLD85's Avatar
heres and easy and faster way i use at the shop. tighten the nut with a small amont of force, one u cant turn the nut, back it of to the first position wher u can slide the coter pin in.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
dyeager535
Aug 28, 2015 08:10 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
