Oil pressure switch on a 2.8
Old Apr 15, 2001 | 01:34 AM
sdevine's Avatar
is it located right near the oil filter and oil pressure sender? Mine is leaking oil out - how do these things stay put? this one is quite loose.
Oh and what is the purpose of the switch?
Old Apr 15, 2001 | 02:08 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
On a fuel injected engine the oil pressure switch controls the on/off operation of the fuel pump! Once the oil pressure reaches a certain level the fuel pump kicks on which usually only takes a split second once the key is turned over!! Once the oil pressure drops to a certain level after the key is turned off then the fuel pump shuts off which again usually only takes a split second once the key is turned off!! As far as keeping one in I can't help ya there because I've never had to replace one but I do know that if you unhook the thing your fuel pump won't work!! This is of course assuming that your 2.8 is FI!!
Old Apr 15, 2001 | 04:22 PM
sdevine's Avatar
Whats the best way to replace it? Should I do it during an oil change or can i pull it out, catch the oil in a pan and put a new one in?
Old Apr 15, 2001 | 04:34 PM
I've never replaced mine so I wouldn't know! I doubt you're going to lose that much oil by taking the sensor out but I could be wrong! Personally, I would probably just do it during an oil change after you've removed the oil filter!
[This message has been edited by 86TpiTransAm (edited April 15, 2001).]
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
