Cant get rid of pinging!!!!
Old Apr 13, 2001 | 03:27 PM
LottaBallsCamaro's Avatar
A few monthes ago I heard my 91RS was knocking, my girlfriend drives it and she hadnt noticed it yet. I made a switch over to premium and it went away. Well, its doing it again and I cant figure it out! I just checked my timing and its at 4degrees which is to advanced but it shouldnt be enough to make it knock.
We are the future, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Apr 13, 2001 | 05:17 PM
ede's Avatar
ede
change your timing and see if it improves. also make sure the est is working
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 14, 2001 | 08:24 AM
bump
Old Apr 14, 2001 | 10:39 AM
Vader's Avatar
LBC,
What Ed said.
If that doesn't uncover any problems, you might be running too hot in the chambers, have hot spark plugs, running too lean, have a dysfunctional EGR, or are accumulating carbon deposits in the chambers.
Check the mixture with a scanner if you can. Make sure the cooling system is circulating through the heads well. Check the spark plug heat range. Check EGR operation. Make sure there are no vacuum leaks, including the PCV and brake booster. GM Top Engine Cleaner can help clean the deposits, or a judicious application of injected water can clean the chambers fairly well.
The newer MTBE fuel formulations can leave chamber deposits, not unlike what us "old farts" used to struggle with when running tetraethyl lead additives. Can you get ethanol blends in your area? It might be worth a try. I've been getting my engines "drunk" on a daily basis since the late '70s and they are cleaner than I've ever seen with plain oil hydrocarbon fuels. They also suppress knock fairly well, since they burn a bit cooler.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 14, 2001 | 10:59 PM
The EST is working. The PCV valve does need to be changed also. I'm going to readjust timing tommarow. Could fuel injector cleaner cause carbon build up? How does water break down deposits? The o2 sensor is reading a good mixture also. I don't know what to do!!!
Old Apr 15, 2001 | 09:36 AM
BUMP
Old Apr 15, 2001 | 05:28 PM
PLEASE HELP!!!!! How can I tell if I have carbon buildup.
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
the_hamturdler
Sep 22, 2015 02:59 AM
