fuel pressure
Old Jul 13, 2004 | 09:17 PM
88'iroczzz's Avatar
Car: 88 iroc z28
Engine: 305 pos
fuel pressure
have a problem!.doing whats supposed to be a simple fuel filter change is givin me alot of ****!.Im sure everyone knows that to take the pressure out the fuel lines you have to take out the fuel pump fuse n let it run till it stalls out.Well on my iroc the fuel pump is sharing the same fuse with fuel injector and it wont start up at all....any ideas on how to do it without just disconnecting the lines and getting gas everywere????.
thanx
Old Jul 13, 2004 | 10:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That fuse for the injector does not control the fuel pump on your car. I know it says FP-INJ2, it doesn't have anything to do with the fuel pump. The fuel pump fuse is the 20 AMP fuse located near the battery. It will either be on the fender or mounted behind the right headlight by the radiator. Also remove the gas cap first.
Old Jul 14, 2004 | 06:54 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You can also pull the relay. Its on the firewall on the driver side.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
