Vac VS Timing
Old Apr 12, 2001 | 07:56 AM
Steve89GTA's Avatar
Vac VS Timing
Less Vac means a retarded timing...?
More Vac means an advanced timing...?
Or is there some sort of peak were I would ge the highest vac before it starts to fall off again. I'm pulling 20in of vac at idle. Before my distributor swap, it was like 21-22 and I had better power down low. Can I just move the distributor counterclockwise a little, start her up and check my vac reading? THanks
Steve
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Apr 12, 2001 | 08:30 PM
ede's Avatar
ede
i have always heard the best timing is at or right before the peak vacuum.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 16, 2001 | 08:08 AM
Steve89GTA's Avatar
BTT
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
midias
Aug 15, 2015 05:07 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
