intake is off
Old Jul 15, 2004 | 06:38 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
intake is off
I got my intake off, managed to break the thermostat housing and one of the connections on the sensor, the vacuum lines i think? Are they hard to ccome by, the housing and the plastic pieces the vacuum lines connect to?
Also found a huge clump of carbon build up on one of the ports on the heads, there was maybe a half inch of space that wasnt covered, I had to get it out with a screwdriver it was so bad. Has anyone ever run into that problem? My car was running rich and I am putting a new intake on and I found this build up and it didnt look to good lol.
I'm also thinking of getting a new distributer to, any suggestions on a not too expensive one for a nearly stock none ECM car?
Old Jul 16, 2004 | 04:17 PM
2 dope's Avatar
Engine: 305 LG4
noone has ever had a port almost completely blocked with carbon ?
Old Jul 16, 2004 | 04:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They block up all the time. Very common.
Accel, MSD, Summit, Performance Distributors are sources for large-cap coil-in-cap HEI.
Thermostat housings are available at you local parts store.
There are 2 sensors on it; one is the coolant temp sensor for the ECM, which you don't need at all; the other is a thermal vacuum switch for the EFE (heat riser) valve. Also widely available at the parts store if you still have the EFE.
Old Jul 16, 2004 | 06:28 PM
2 dope's Avatar
Engine: 305 LG4
I have neither, wonder if my car originally had an ECM? Its not there now but I cant see GM putting the sensors there if it didnt have an ECM
Old Jul 16, 2004 | 06:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Maybe not. Alot of the Canada cars didn't have them.
But the EFE one I believe was there regardless.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
