temp too high?
Old Jul 17, 2004 | 10:36 AM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
Transmission: stock 700r4
temp too high?
I have a stock 1986 iiroc-z. What should my temp. be ? Recently i have noticed that my running temp on the highway during the afternoons without my ac running averaged about 220. When i turn on my ac. it drops. that got me looking at the fan and what temp. it cut on at. I started the car and let it run while watching the fan. It started at 240. Is this normal? Should I look at fan relays? Water pump and thermostat are new.
Old Jul 17, 2004 | 01:56 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: temp too high?
Your setup is functioning normally. If it bothers you then get a relay that kicks on sooner. Your gauge could also be out of calibration. I have headers and the gauge reads 20* hotter cuz the sensor is next to them. I think relays run about 50 bucks. You can get them to kick on at 185.
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
wisemanz28
Sep 20, 2015 01:26 PM
corey8084
Sep 17, 2015 02:56 PM
DARKmj16
Sep 9, 2015 04:07 PM
