oilling modification on a small block chevy?
Old Apr 17, 2001 | 01:02 PM
burnoutrpm's Avatar
what mods can a person do at home to the oiling system of sbc to make it even more efficent? remeber: no expensive parts or special pans. i hear you can drill out the opening on top of the oil pump?
89 firebird formula
356 10.5:1compression CURRENTLY DEAD!!! BEARING FAILURE!!
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
current engine underway..sucks not having a car!! Building the same engine but .060 over balanced and blueprinted..decided to get a little more serious this time around!!
Old Apr 17, 2001 | 02:40 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
There are no real mods needed for chevy oiling. You can grind out the casting left in the back holes by the distributor to improve oil drain back. Get a windage try for the bottom end and a good oil pan. If you really want to try something grind out the casting in the rear main cap where the oilpump sits and you can enlarge the holes from the cam bearings to the mains to the size of the main bearing hole.
Old Apr 17, 2001 | 06:15 PM
ede's Avatar
ede
i tap the drain holes in the front half of the lifter valley and put plugs in, use a #26 spring from mr gasket in a melling m55 pump, use arp pump drive shaft. use the baffle between the pump and main cap, gring all casating flash, glue screens in the big drain holes, if you have solid lifters you can run restricters in the lifter oil gallies, radius the oil holes in the crank, run a drill bit in the oil feed holes to the mains to clean them out, if you make them bigger it's all good. windage screen and crank wiper.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
