A/C 'off' but compressor still comes on
Old Jul 17, 2004 | 07:23 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Hey guys, just recently I noticed that the A/C Compressor isn't really turning off when I set the HVAC controls to off. There is still cold air coming from the vents (without the blower) and I can feel the loss of power when the A/C compressor clicks on. I looked through my chiltons and they don't mention it, and I tried a search here but again no luck.
What should I check first?
Thanks in advance.
-Steven
Old Jul 17, 2004 | 07:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
For an interm solution, you can disconnect the plug on the compressor...I had a buddy who had the same thing happen, his problem was in the switch itself, only time the comp would shut off was when he selected "fan".
Have you tried other positions on the selector? Could be things are worn and need to be replaced/adjusted.
Old Jul 17, 2004 | 08:25 PM
StevenK's Avatar
Car: 91 Z28
I remember a few months back I would have to go back to an A/C funtion then off again to get it to turn off. Could it possibly be a vacuume relate issue?
Thanks for that hint on disconnecting the compressor, thats a good idea.
Old Jul 17, 2004 | 08:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don'ton't think it's vacuum, but more in the switch assembley(least from what I dealt with).
Old Jul 17, 2004 | 08:52 PM
incus86's Avatar
Car: 1992 trans am ws6
Engine: l98
Transmission: t-56
if its vaccum i believe the hvac vacuum line goes to that round black thing that has the tb coolant goin into it.
Old Jul 18, 2004 | 01:38 AM
StevenK's Avatar
Car: 91 Z28
if I go to vent the A/C turns off. I'll pull the whole HVAC thingy out later and see if I can see where the problem is.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
Ironhead38
Sep 7, 2015 02:26 PM
