burning oil???
Old Jul 17, 2004 | 11:17 PM
chevyss99's Avatar
burning oil???
i have a 1987 camaro with a 305 tuned port, i had to rebuild my lower end this year so why i had the motor out i put new umbrella seals in because never were changed, and it would smoke when first start. when i put the motor back in car when i get off the gas or take off fast it smokes pretty good never had this problem before does it sound like a seal pinched or piston ring ? any info would be great
thank you
Old Jul 18, 2004 | 03:59 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Well if you used just umbrella seals, I would say you should have went with positive seals.
Old Jul 18, 2004 | 11:39 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
yup, Umbrella seals aren't the best form of valve seal out there, but they aren't the worst, either. Most positive types require machining to the guide boss. However, Fel-Pro makes viton seals that do not. Assuming factory guide boss size, SS72527 is the part number for the intake and SS72877 is the exhaust. They can be had at Advance Auto, or any other Parts America store.
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
my86bird
Oct 23, 2015 12:20 PM
CatmanFS
Sep 19, 2015 09:00 AM
