K&N cleaning ,, how often??
Old Apr 17, 2001 | 12:09 PM
rondubbs's Avatar
how often should i clean my K&N for optimal performance,, i do regualar city street and highway driving,, no dirt roads,, but i just make a homemade cold air induction so that may cause more dirt to build up,,
so how many miles between cleanings???
1988 GTA Trans Am 350tpi: 46k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, homemade cold air induction, flux capacitor, driver side floor mat removed
Old Apr 17, 2001 | 12:18 PM
burnoutrpm's Avatar
i clean mine about every 25,000 miles and in between just tap the excess off on the ground gently.they are very durable filter that rarely need service.
89 firebird formula
356 10.5:1compression CURRENTLY DEAD!!! BEARING FAILURE!!
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
current engine underway..sucks not having a car!! Building the same engine but .060 over balanced and blueprinted..decided to get a little more serious this time around!!
Old Apr 17, 2001 | 10:07 PM
jase's Avatar
You can go as long as the manufactor recomends since you don't have any dusty places.The man. rec. 50,000.The dirt helps up to a point.Mine ran well but my milage started to suffer,so I cleaned it and I notice ahughe difference.
Old Apr 17, 2001 | 10:35 PM
raging86's Avatar
hey ron, replace it every time you replace your high performance floor mats!
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Old Apr 17, 2001 | 10:39 PM
Vader's Avatar
Ron,
Since you get a lot of humidity, hot, and cold weather, I'd clean and re-treat it at least once a year. The oil that treats teh filter can get pretty nasty and gummy from the water and freezing air.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
