question about TA headlights... how many watts ???
Old Apr 18, 2001 | 09:40 AM
cica55's Avatar
alright, I have 85 TA , and to be honest with you , my headlights SUCK *** !!!
and no , it's not because they are old , actually they are brand new , adjusted right and still suck *** ... can't compare that to any other car that I've driven...
so , I checked out AutoOptiks and they have conversion kits for our cars.
here are my options..
#6054C - Autopal #6054 DOT Sealed Beam Conversion Kit (Pair), Uses H-4 Bulbs $50.00
#6054CE - Autopal #6054 ECE Sealed Beam Conversion Kit (Pair), Uses H-4 Bulbs $50.00
#6054CL - Autopal #6054 ECE w/CL Sealed Beam Conversion Kit (Pair), Uses H-4 Bulbs $60.00
#H4GH - Astra H4 90/100W Gold-Dichroic Capsule (Pair) $25.00
#H4U - Astra H4 55/60W Ultrawhite Capsule (Pair) $25.00
#H4UH - Astra H4 90/100W Ultrawhite Capsule (Pair) $25.00
#H4H - Astra H4 90/100W High Output Clear Capsule (Pair) $25.00
#H4HH - Astra H4 90/130W High Output Clear Capsule (Pair) $25.00
#H4AW - Philips H4 55/60W Allweather Capsule (Pair) $40.00
#H4BV - Philips H4 55/60W Bluevision Capsule (Pair) $30.00
#H4P - Philips #H4 55/60W Premium High Efficiency Capsule (Pair) $40.00
Philips #H4 Xenon HID Conversion Kit (Pair) $550.00
obviously I would like to get the HID kit , but that's just too expensive for me right now, SO , I'm going to go with the DOT sealed beam conversion kit , but I don't know what H4 bulbs to get...
so , the question is...
thank you for any info that you can give me. I think I want to go with the highest wattage possible , so 90/130 , but will I encounter any problems with this ?
also , what is the output of the stock headlights ? (just so I can compare how much improvement I might get).
Old Apr 18, 2001 | 07:44 PM
Steves ZZ5's Avatar
IIRC the wattage of our stock headlights is 35w for the low beams and 55w for the high beams.
I'm at work right now, or I would check for sure on the packaging I have from my old lights.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
