tpi hesitation
Old Apr 18, 2001 | 08:43 PM
bad camaro RS's Avatar
tpi hesitation
my hesitation seems to be getting worse when i first started notice it it was only if i got on it off an idle now jus about anytime i hit the gas fast it cuts out and sometimes if i punch it to the floor real fast i can have the pedal on the floor before it takes off ive check my tps ive had it from .54 to .62 and it changes nothing ive reset my iac could my maf be getting slow? any ideas would be greatly apprecated thanks
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 18, 2001 | 08:52 PM
Vader's Avatar
RS,
Try resetting the minimum throttle position. The IAC can compensate for a lot of variation in the throttle idle position, so the minimum air setting can wander quite a lot before you will notice any problems - like hesitation. After cleaning the throttle body and IAC air passages, reset the position and TPS voltage as necessary.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
[This message has been edited by Vader (edited April 18, 2001).]
Old Apr 19, 2001 | 07:53 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I was thinking about this problem since every TPI owner is a perfectionist (me included, so don't get on defense) because our cars are computer controlled and should be perfect all the time.
And my car hesitates (slightly, no one else notices) the first time I really lay into it since starting.
It either does this as soon as I mash the gas, or on the 1-2 shift. But only does it once per start.
Now I heard the knock sensor tests itself at over a certain throttle position by over advancing the timing to see if it 'hears' knock.
I know I am getting knock counts, but only here, so is this true? I have to do the wicked burnout just to get it out of its system so i could race.
I retarded the timing and run slower after this bs is done so this is the point i'm at. If I advance more I get counts and run slower. If I retard, I won't have the prob of the 1st time hesitation, but will run slower afterward.
Any input? I'm running a custom chip (TPIS stage 5) for my combo (supposedly, since I never knew about this board before, I'd like to shove it down their greedy throats!, by a burner and have at my own chip... which I still may do)
Old Apr 19, 2001 | 10:36 AM
raging86's Avatar
i wouldn't totally rule out the TPS. i have heard and seen them produce good voltage yet still be bad. i can't remember how much a new one is, but i would at least give it a shot. i know just bolting stuff on is never a way to fix a problem, but by replacing it you could be totally sure it is good. my TPS went bad last year, its symptoms were, poor throttle response, and kinda messed up idle characteristics. it was so bad that when you went to take off sometimes, you would give it gas to take off from a dead stop and it wouldn't do anything, so you would give it more and more, then all of a sudden it would decide to go(the whole process took about 1 sec.). my mom had to drive my car one time and she wasn't used to it, so when it didn't respond she just kept giving it gas, when it decided to go(about 1/2 sec later) it peeled out in the driveway! my dad and i about lost it.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
retro-roco
Classified Ads Feedback Board
Aug 12, 2015 07:23 AM
