how much compression estimate
Old Jul 21, 2004 | 08:35 PM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
Transmission: 4 speed manual
on a 406 .040 over with vortec heads also will i be able to run pump gas
Old Jul 21, 2004 | 09:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
CR depends on the pistons (dish or dome volume), deck clearance, head gasket thickness, in addition to CID and chamber ccs.
These guesses will use the "spec" for Vortec heads, which is 64cc; your heads may vary.
If you have stockish pistons with a 18cc dish, and they're .030" down in the hole (typical stock), and you run a .039" head gasket (FelPro 1014 for example), your CR will come out to about 9.6:1.
On the other hand, if they're flat-tops with typical 6cc valve reliefs, zero-decked block, and a .018" steel-shim gasket, it's 12.3:1.
Pretty wide range there.... from pretty comfortable with pump premium, to no way in Hades.
Sounds like you need to gather some more info in order to be able to make a more nearly informed decision.
Old Jul 22, 2004 | 04:43 PM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
thanks for reply sorry i forgot they are flattops with 2 valve reliefs
FormulasOnly
Jul 23, 2018 08:47 AM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
