electric fuel pump
Car: 1985 Camaro Z 28
Engine: 305 LG4
electric fuel pump
Can this type be used on my car?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33555
do i just take the old one off and put the block off plate on?
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
Re: electric fuel pump
You'll need to block off the stock mechanical fuel pump location w/ a block off kit.
You WON'T need a fuel pressure regulator for this one.
You'll need to hook up a 'keyed hot (+) wire' and a ground (-) wire (to frame) to operate the fuel pump.
I have mine mounted halfway under the car (driver's side - mid door), 6" in front (towards engine) of the in line fuel filter.
Good luck... great fuel pump.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
