2-bolt vs 4-bolt
Old Jul 23, 2004 | 03:14 PM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
2-bolt vs 4-bolt
What is the difference between a 2-bolt main and a 4-bolt main? In general, do most people prefer 4-bolt. Also, did any of the Formula TPI 350 come with 4-bolt?
Old Jul 23, 2004 | 03:19 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No 3rd gen L98 350's came with 4bolts, they are all 2-bolts. The only L98 350's that had 4-bolt were the Corvettes. The number of bolts refers to the number of main cap bolt there are. 4-bolts are generally thought to be stronger on all SBC's except the 400. But for anything driven on the street it doesn't really matter and number of bolt will be strong enough.
Old Jul 23, 2004 | 07:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
A 4 bolt block costs nearly twice as much to buy main bolts for, as opposed to a 2 bolt block.
Old Jul 24, 2004 | 12:42 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Alot of people will argue that 4 bolts arent really that much stronger than 2 bolts. Alot of people also run the crap out of their 2 bolts and rev them hard and dont have trouble.
Personally I think the best bet is to get a 2 bolt block and have it machined to accept 4 bolt caps where the two outer bolts go into the block on an angle. These are alot stronger than the standard straight 4 bolt block.
Old Jul 28, 2004 | 12:47 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
i agree that the 2-bolt converted to a 4-bolt splayed setup is ideal, but i disagree that a 2-bolt will hold up to anything on the street. how many times have you heard of someone grenading their block from pushing it too hard. 2-bolts just wont rev as high or hold up if you're pushing serious power.
Old Jul 28, 2004 | 01:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Grenading the block? Almost never on any kind of streetable build.
FstBrd6point3
Feb 24, 2005 08:04 PM
GlenYappa
Oct 31, 2001 04:53 PM
G92Joe
Sep 3, 2001 10:55 PM
ae420gd
Mar 22, 2001 11:32 AM
TRAXION
Oct 30, 2000 10:45 AM
