Fouled O2 sensor symptoms?
Old Apr 19, 2001 | 09:17 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I just hooked up my Autometer A/F ratio gauge and I'm getting some strange info. I was wondering what the symptoms of a fouled O2 sensor were? I was reading about the workings of the O2 sensor in the little instruction sheet that came with the gauge and it said that running too rich could foul the sensor. Not too long ago I was having a problem with fuel delivery and fouled all 8 plugs...think the sensor went too?
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Apr 20, 2001 | 07:15 AM
350HOZ28's Avatar
It could be on the brink of going out due to a over rich fuel mixture...depends on how long you drove it that way. It should really being throwing a code 32 on the SES...probably when you are driving around for a while at speeds around 45-55 mph, your SES light may come on and won't go off until you restart the car. If you have your A/F gauge hooked up correctly, and you are in doubt, I would just buy a new one. They are only around $20, and will help your fuel economy some as well.
1984 Z28 - L69 optioned, 350HO w/ Trick Flow Heads, Drop Forged Lunati Crank, Crane Cam and 1.5 Roller Rockers, Stock Z28 Intake Manifold, Highly Tweaked Rochester Carb(700cfm), K&N Filter, ThermoMaster Chip w/ 160 Stat, Comp Headers, 3" Stainless Dual Exhaust w/ no Cat & Dynoflow Muffler, 4 wheel disc brakes, etc....
God bless us father, son, and holy ghost....whoever goes the fastest wins the most!!
Old Apr 20, 2001 | 07:30 AM
ede's Avatar
ede
check the voltage output with a DVM. the senser generates voltage and if it isn't working correctly you'll find that with the voltage check.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 20, 2001 | 02:25 PM
Mark305TBI's Avatar
So, if the sensor if fouled it will send an overly lean signal? The gauge will drop off the scale on the lean side repeatedly, sometimes for an extended period of time. The auto-x-ray shows the same ultra-low voltage, so it's not the gauge itself. It's bizzare.
-Mark W.
Grizzly_Addams
Mar 29, 2005 10:36 AM
Streetiron85
Carburetors
Mar 8, 2003 05:52 PM
GTA88
Jul 14, 2001 08:36 PM
87kevroc
Jan 30, 2001 01:33 PM
