What should I do first to get rid of a bad miss?
Old Apr 20, 2001 | 10:41 PM
AustinT's Avatar
remember my post about the zz430 with no power running open headers, well now I have a hooker exhaust on it and I can hear the engine better.
It pulls pretty good to about 3700 rpms then it misses way bad. My timing is 12 Btdc. Carb is a holley 750 vacumm secondary with 71 jets in the front and 73 in the rear. What should I do first The peak torque for this motor is about 4000 rpms and this is when it starts to miss way bad
Old Apr 21, 2001 | 07:32 AM
ede's Avatar
ede
without knowing what all you've done or anything i'd say change the timing a little, change the springs in the advance ,verify you have a good fuel supply and preasure. are you sure the lifters are adjusted right? no bent push rods or broke valve springs?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mddaniel
Sep 8, 2015 05:16 PM
db057
Aug 22, 2015 08:17 PM
stalkier
Aug 21, 2015 01:54 AM
Bryan F
Aug 18, 2015 02:28 PM
