piston broke
Old Jul 25, 2004 | 04:07 PM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
piston broke
can anyone tell me why the one tail like tab on a piston would break off? i just got the engine used and was told it ran great before it was pulled 2 weeks ago... was going over everything on it and found a piece of metal in the pan and a washer??? then found where the piece of metal went ... on the end of the piston.. there is no where i see that it would have contacted anything but it still is broke off and clue why?? i may be able to get a picture on here later if it helps.. thanks all...
Don
Old Jul 25, 2004 | 08:54 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Usually things like that develop from manufacturing flaws (these can be very minor) and are made worse from vibration, heat cycles, etc. Take a look at it and see if there is an old crack, then a shinier new crack at the break line. At any rate it really doesn't matter, hopefully it didn't make a lap in the cylinder and screw that up. If it didn't scratch the wall and if it's a factory piston you can usually just replace it. Since you have to buy a set of rings, you might as well hone and ring the thing. Since you'll have the rods out, you might as well replace those bearings too. Whenever I use cast pistons, I am real careful to deburr the skirt area to prevent things like that from happening. (cast pistons are more susceptible to cracking than forged IMO).
Old Jul 26, 2004 | 06:20 AM
3rdGenSS's Avatar
sounds like what it did... the cylinder wall looks fine.. and you can still see the hones in it... it almost looks as though it was rebuilt not long ago.. the bearings look pretty much new from what i can see... but like you said i have to get the ring kit and will have the rods out.. so might as well hone it.. get a new piston... rings.. and bearings and put it back together... thanks for your reply...
Don
Old Jul 26, 2004 | 07:30 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What did you pay for it? I think i'd be asking for some of my money back..
Old Jul 26, 2004 | 06:13 PM
3rdGenSS's Avatar
Paid 300 for the long block... the guy swears it ran great when it was pulled and there was no other metal or anything in the oil and the top end was very clean.. so far everyone that has looked at it is saying to just put a new piston and rings in.. the bearings look pretty much new. just trying to get some opinions from people on here..
Old Jul 26, 2004 | 07:09 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
Re: piston broke
Originally posted by camaro86vette
piston broke
I thought by the thread title it was gonnig to be about being drunk with no money
Old Jul 28, 2004 | 10:20 PM
Car: 83 Z28
Bubbajones_ya
Oct 25, 2015 08:01 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
