Is this good for the first oil change...
Old Jul 25, 2004 | 08:09 PM
Erin91RS's Avatar
Car: 91 RS
Transmission: 700-R4
Well on the new 383 (Eagle crank, H beams, Speedpro 10:5:1's) I got just over 600 miles on it so far. Oil pressure about 50ish on the highway when hot and about 25 at idle. I went with a stock melling standard volume standard pressure pump. I was using Dino 10-30 oil and a PF35 filter. On this change I used the same oil 10-30 but only could find an ac PF 454S filter so I used that. It seems my pressure is higher now. Maybe because the first filter was clogged with stuff? I dont have a bypass anymore. I went with a Canton Oil Filter unit. When I opened the filter it seemed clean but with some very fine specs here and there, but noting else. Is this normal for the first oil change on a new motor?
Old Jul 26, 2004 | 12:40 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Sounds like it to me...
Old Jul 26, 2004 | 12:47 AM
Rainman's Avatar
Car: 1989 Firebird Formula
Transmission: WC T-5
Axle/Gears: Moser 12 bolt, 3.73 gears
It is normal to find small pieces of metal in the filter after a fresh rebuild. it is just the internal parts establishing a wear pattern. i would only worry if you had big chunks.
Old Jul 26, 2004 | 04:19 AM
ede's Avatar
ede
usually on the first oil change on a fresh rebuild you'll fild lot of assenbly lube and lint from towels, or traces of it. especially if you use moly you'll find the oil very dark. you shouldn't be finding any metal pieces. are you sure it's metal or is it just specs of something?
Old Jul 26, 2004 | 01:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
It "could" be something else. Thre wasnt enough to see if it was metal or not. Just a shiney spot here and there. Could have been the light or the "shavings" that fell in there when I opened up the filter with a hacksaw. lol
Old Jul 26, 2004 | 05:52 PM
MuscleMadness's Avatar
Car: 1989 Trans-Am
Engine: 305 TBI
OMG!! Too funny!
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
