combination opinions
Old Apr 21, 2001 | 02:27 PM
84zeddd's Avatar
Hey guys,Im new to this board but I would
like your opinion on my combination.It is
an 84 camaro w/355sbc.10.5:1 compression
200 c.c. dart heads,crane cam(.454 216int.
.480 228exh.)crane roller rockers,600 holley w/lightest spring,edelbrock performer intake,shorty headers,dual cats and mufflers,6al msd,accel coil,700r4 w/corvette servo,stock converter,3.73 gears,auburn diff.
Im hoping for 13.5-13.8@101-103mph
Car wieghs 3650lbs w/driver
Please let me know what you think.Would like
to hear from people running similar combo
THANKS GUYS
Old Apr 21, 2001 | 03:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Cam is too small for the heads and the CR. You've got giant ports, but the cam only barely cracks the valves open. You're wasting a sizable portion of the flow you've paid for by buying those heads.
Carb is too small. It will lean-bog with the lightest spring on that small of a motor.
With a Comp XE274H, 1.6 roller rockers, and a Holley 750, it will be in the very low 13s, maybe crack the 12s. As you have it described, I'd guess 13.5-13.6. However, with the motor's mismatches corrected, you will have a serious traction problem off the line; you'll definitely need some rear suspension work to get the most out of the motor.
ICON Motorsports
Old Apr 21, 2001 | 04:20 PM
84zeddd's Avatar
Thanks for your input RB83L69
Car came with the dart heads.Cam,carb and
intake are a compromise to try to meet
emissions.The carb spring I havent had a chance to really test.I know everyone says
my cam is too small but I dont really like
high stall converters and this cam has great
bottom end and should let me keep the shift
points safely bellow 6000rpms
THANKS AGAIN
Old Apr 21, 2001 | 04:43 PM
ede's Avatar
ede
well rb beat me to it. the cam is too small and i'd say the carb also. i'd run a weiand stealth intake instead of edlebrock. you have real close to the engine i built for my sons 88 camaro. he's running a lunati bracket master with .515 lift (i think) plus 1.6 roller rockers, brings the lift to around .550.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 21, 2001 | 10:53 PM
84zeddd's Avatar
I know my cam is small but it is emissions
legal. I know the xe274 is not.Im not sure
about the lunati.Maximum performance is not my ultimate goal.What I want is good street manners with no bad side affects(low vacuum,
loss of bottom end torque,hard hot starts)
I know from previous experience that this
cam will work with stock torque converter
and will pull to 6000rpms and thats what I
was looking for.I also heard that with the
700r4 that the large gear spacing favours a
long flat tourqe curve.I hope that I am not
too far off base.
THANKS AGAIN FOR YOUR INPUT
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Jlanz55
Sep 29, 2015 08:55 AM
