knock senser
Old Jul 26, 2004 | 09:37 PM
sockfootball22's Avatar
Car: 84 z28
knock senser
can i get the connector that goes on the senser at an autoparts store or not. mine is like all melted. thanks in advanced
Old Jul 26, 2004 | 10:11 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
IIRC, it uses the same connector that fanswitches use so if you can get a pigtail for a fanswitch that would work equally well. I think some stores carry the pigtails. If not im sure a pigtail for the ks could be located at a junk yard, internet, or on the classifieds.
Old Jul 27, 2004 | 12:49 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I found one at an auto parts store once, but it was only cause I knew what it looked like. It wasn't "labeled" for either a knock sensor or a fan switch. So you might have trouble finding one without being able to show the minimum wage dude behind the counter what it looks like.
But you can still get it from the dealer too. Edit: about $15
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
