305 cam transplan!
Old Apr 20, 2001 | 08:16 PM
rokkgod's Avatar
305 cam transplan!
ok, so now i've learned that the 305 with a 5 speed has a differant cam than the automatic. can i just get a cam from a 5 speed 305 (through a chevy dealer i supose) and have it put in my automatic 305 or will this cause a problem of some sort with the cars computer and other part?
Old Apr 20, 2001 | 08:55 PM
Guest
Guest
Posts: n/a
The computer wont care, but before you go and do that... what year is your car?
Old Apr 21, 2001 | 07:31 AM
Nitro Don's Avatar
Yes you can swap in the cam that came in the 5-speed,but why? You wont feel a difference!
If you go through all the work of installing a cam,why not put in something better that will help you make some decent power.Unless
you get the cam for free,stay away from it.
I ran a 210/220 .533/.544 cam in my 90 TA,
using the stock chip,and it ran fine.Just make sure the cam you select is a TPI computer compatable cam.
Hope this helps,
Nitro Don
Old Apr 21, 2001 | 09:52 PM
rokkgod's Avatar
hey nitro, will this cam give me significantly more power? about how much? also, will the idle be good? this is a street car.
Old Apr 21, 2001 | 11:35 PM
Vader's Avatar
Rok,
Check out the Comp Cams web site or catalog. Look for something with a .450" to .48" lift range and 112° - 114° LSA. There are several choices designed for use with computer controlled engines and will provide very good power gains and street-friendly operation. If your engine is an '87 or newer, you're lucky in that you can choose a roller cam.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 22, 2001 | 12:16 AM
MrJ's Avatar
MrJ
If you have an 85 or a 90-92 car, don't bother with the swap, because you already have the same cam as a 5 speed car. If you have a car that really is peanut cammed, I'd go with a grind better than what GM put in these cars stock, like an LT4 production cam or something similar.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
