Vortecs
Car: 4
Engine: 6
Transmission: 5
"Stock 350".... covers alot of ground.
The only "stock" heads in 89 were either TBI heads, iron L98 heads, or aluminum L98 heads. The first 2 have 64cc chambers, the aluminum ones have 58cc chambers.
Vortec heads are 64cc. If you don't know exactly what you're working with, preferably by casting number and piston part number, it's near about impossible to predict what it is now, and what it would become.
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
sorry for not making that clear enough. anyways, its a 89 completely stock 350 tbi motor. it has a lt4 hotcam, rpm airgap intake, stock vortecs (stock gaskets), 1 5/8 headers
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Completely stock 350 TBI...What is this engine from? Assuming the heads are the 193 swirlie heads, they are cast as 64cc.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by 92lt1
the motor is from a camaro.
Car: Z28
Engine: Sb2.2 406
THe L05 was never an option for the F-body, so something isn't lining up here.
Anyway, assuming it is the 193 heads, you should have no real compression difference.
*edit* There is a strange phenomenon that occus upon selling a car. Somehow the 305s turn into 350s.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
That is pretty weird aint it? When I was f-body shopping before I found my current camaro I musta looked at 4 cars all claiming to be 350's ...you cant argue with the owners either cause they know EVERYTHING. Well, anyway...
Vortecs are claimed to be 64cc but everyone I know who has actually had them cc'd has come closer to 61-62cc's. So, swapping a set of 64cc heads for Vortecs just might raise your compression a little ...not much, but they might.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
On most stock GM motors a "stock" head gasket means a .015" shim gasket. If you now have a typical stock replacement gasket (.038 to .046") thick and didn't deck the block then your cr would now be lower than stock.
It's all in the details.
I was under the impression that the stock 350 TBI head had a 76cc chamber.
Car: '87 Formula
The '193's that came on my L05 were claimed to be 64cc by Pace Performance, and some other sites I found that sold the Caprice replacement engine. I didn't measure them myself but I'll take their word since they are marketing those numbers.
Chas91Z28
Oct 22, 2015 10:12 AM
monte87cortez
Sep 26, 2015 08:10 PM
