can i use auto xray to dianose fuel pump?
Old Apr 22, 2001 | 12:43 AM
chrisfrerick's Avatar
i have an autoxray scanner and i think my fuel pump is weak and might fail in the near future. can i use my auto xray to see if its not up to standards ifso what readings should i look at. i do not have a fuel pressure tester and around here they will tell you that your fuel pump is bad and you need to replace it reguardless if something is wrong with it.
88 iroc 350 auto slp 1 3/4 headers,slp cam with .487lift,tpis intake manifold,tpis runners,msd ignition,k&n filters.
thermomaster chip with fanswitch and 160 thermo,transgo prokit with shift kit and upgraded torque convertor.factory 2.77 borg posi rearend koni sport yellow shocks and eibach lowering springs
Old Apr 22, 2001 | 01:52 AM
Vader's Avatar
Chris,
The scanner will not read fuel rail pressure. You need a pressure gauge for that, and that is the most effective way to test the fuel pump capability. A good pump should be able to produce at least 60 PSIG when dead-headed (no flow or return fuel from the regulator). The other test is a flow test, where the pump is allowed to pump fuel for fifteen seconds into an open container. A good pump should flow at least one pint in 15 seconds.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
92camaroJoe
Aug 13, 2015 06:07 AM
