fileing piston rings
Old Jul 28, 2004 | 03:12 PM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
when filing pistons how do you know how much to file it seems like it would be easy to go to far so how do you know?
Old Jul 28, 2004 | 03:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You put the ring in the bore, making sure it's absolutely straight, and check the gap with a feeler gauge. Repeat as necessary.
Old Jul 28, 2004 | 07:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup. If you got a flat top piston, that works well for getting the ring straight like RB was talking about. Just put the ring in the bore, then use the face of the piston to push it in straight.
Old Jul 29, 2004 | 02:10 AM
a73camaro's Avatar
Use a "constant" pressure while filing, then count the number of files. Start with 10 to get a feel with how much filing you need to do. Once the first ring gap has been established, repeat but do a few files short of the number from the last cylinder.
Old Jul 29, 2004 | 04:09 AM
ede's Avatar
ede
buy a ring filer, it'll save you lot of extra effort, but it is easy to go to far if you aren't careful. use a tri square or ring squaring tool to check the end gaps. i use a stepped feeler gage to check end gaps so i know when i'm getting close. i made my squaring tools out of a piece of tefelon pipe in a lathe.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
