installing piston
Old Jul 29, 2004 | 08:41 PM
88Z's Avatar
88Z
Car: 88 Iroc
installing piston
I just took out my piston to check something, and now i just wanna throw it back in. I marked the top of the piston to reinstall the same, but is there a specific way the rings should be positioned put before i put it back in?
Old Jul 29, 2004 | 09:09 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
just make sure none of the gaps are lined up with the other rings, they should all be stagered.
Old Jul 29, 2004 | 09:59 PM
Vader's Avatar
That means staggering the oil ring rails as well. You chould also avoid aligning any of the ring gaps with the piston pin area.
Old Jul 30, 2004 | 05:45 AM
ede's Avatar
ede
i hate to ask stupid questions but why would you remove a piston just to look at it? and why would you remove a pistion not knoing the details on how to reinstall it? your manual might or ought to show the correct ring gap positions.
Old Jul 30, 2004 | 06:59 PM
88Z's Avatar
88Z
Car: 88 Iroc
I had oil getting to my spark plugs, and i tore apart my motor before doing a leak down test. So instead of putting my heads back on, i just took my piston out to check the rings. I've since found out the correct gap positions. If looking at the piston from in front of the motor, the gaps from top to bottom should be at 12 o'clock, 3 and 9.
Old Jul 30, 2004 | 07:42 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
doesnt sound like you should have torn it down then ...lol...was it problems with valve seals ????
Old Jul 30, 2004 | 09:11 PM
88Z's Avatar
88Z
Car: 88 Iroc
haha yeah, leave it to a mechanic to tell me it was valve seals, THEN to tell me we should've done a leak down test I guess we'll find out whether it was the heads or not after i throw on some with a fresh rebuild.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
