Fuel injector question
Old Jul 31, 2004 | 03:18 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Can I use injectors from an 85 V6 firebird in my 87 firebird? When I pulled out the injectors from the junkyard car, I found two were different. The numbers on top are D167 and 5235136. Are these ok to use as well? Here's pic.
Old Aug 1, 2004 | 11:43 AM
Vader's Avatar
They should be compatible. Coil impedance is the same, and flow rates should be the same or close enough to operate correctly. As long as they are not dirty or leaking internally, it should work.
Old Aug 1, 2004 | 12:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right.... in different years, they used different suppliers or versions of them, that are more or less equivalent functionally....
For best results, send them to www.cruzinperformance.com and get Rich to clean and flow-match them.
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
