lights out help...
Old Jul 31, 2004 | 04:16 PM
88 IROC Conver's Avatar
lights out help...
I need help. I lost my head lamps, they went out then back on etc. I am looking to find what the meaning is of g5, c100, s201 on the wiring diagram I think c100 is the connection thru the firewall g5 is the connector in that plug and s201 is a splice any help would be appreciated.
Old Aug 1, 2004 | 11:37 AM
Vader's Avatar
You are correct. However, "S201" is buried in the wiring harness somewhere, soldered and wrapped with tape like the rest of the harness. Finding it can be a chore, as with any other factory splice. If you suspect it is bad, uyou can temporarily jumper around the suspect section of harness to confirm your diagnosis.
Old Aug 1, 2004 | 11:53 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
This should help narrow your search down some.
Old Aug 1, 2004 | 05:47 PM
Hey trixter, do you have all those nice copies of the gm book in a file you can e-mail? if so I will sent you the address. this last picture is fantastic! thanks
Old Aug 1, 2004 | 06:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I can make the file easily enough, which ones do you need?
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
