misfiring and it gets worse as i get up in the rpm
Subscribe
Apr 23, 2001 | 08:47 PM
ok im at my ropes end idleing and causal driving it doesnt seem to mis a lick but when i step in to it around 4000 its starts misfiring real bad ive replaced wires ,plugs, cap,rotor unhooked msd and msd coil and hooked up my stock ignition and coil and it still does it so i know its not them i replaced cap a week ago checked it today and it had a little grove between the terminals where it has been misfiring so i put another cap and rotor on it but it still mifiring when i get on it could it be my distibuter?computer? whats ? i have never been so baffeled please help later
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Reply 0
Apr 23, 2001 | 08:58 PM
well i think you're on the right track, you need to check and make sure you have a good tune up. also check fuel preasure and volumn and i'd do a compression test. no codes set?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Reply 0
Subscribe
