changed plugs now have a tick
Old Apr 23, 2001 | 08:40 PM
ChrisR's Avatar
I changed the plugs and the oil today and now I have a tick coming form around the 2 and 4 cyl.
I made sure that they were not cross threaded. I had Bosh Supers in it, not I put A/C Delco's in. What did I do? I checked the wires too. I feel so stupid.
Chris
1987 GTA 350,rebuilt in 1998. new heads, Heddman headers w/y-pipe, Dynomax cat-back system, 45,000 coil, accel plug wires and cap&rotor, k&n, b&m shift kit and trans cooler, modified mass airflow sensor, manual fans switch. MSD 6A yet to be installed. No time slip.
1993 Bonneville SSE ALL STOCK. 98,xxx miles and stil counting...plan to install K&N and Flowmaster 80 series
Old Apr 23, 2001 | 09:03 PM
ede's Avatar
ede
it's either a spark jumping to ground or compression leaking. if it's compresion you ought to feel it with your hand, if it's spark you don't want to feel it with your hand
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 23, 2001 | 11:00 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
If it is a spark jumping somewhere, try looking at the engine in the dark. Turn off the underhood light at night, and if there is a spark going somewhere it shouldn't it ought to be easy to spot it in the dark.
eightsixseven
Dec 16, 2024 01:50 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
