1988 IROC 5.7 fan question
Old Aug 2, 2004 | 08:23 AM
johnnyb's Avatar
Engine: 5.7L
when I jumper the diagnostic port as if I were going to run codes, only the driver's side fan comes on. The fan on the passenger side never comes on, even when the coolant temperature reaches 240 degrees. I want to check the relay, but I don't know it's location (there are a lot of them). Is there something else it could be (besides the fan motor)? Where can I find a wiring diagram of the twin-fan circuit? thanks!
Old Aug 2, 2004 | 09:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Passenger side comes on only when the A/C is operated.
Old Aug 3, 2004 | 11:34 PM
johnnyb's Avatar
Engine: 5.7L
hmmm...I'm pretty sure they both used to run when I shorted the diagnostic port. could be wrong, I guess. I'll check to see if they come on when I switch on the A/C. thanks!
jb
Old Aug 4, 2004 | 10:07 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
On my 88 they both run with the AC, driver's side runs on diagnostic and mid temp from ECM, passenger side runs from high temp on it's dedicated sensor, passenger side head next to exhaust down pipe. Whole bank of relays just above the master cylinder.
Old Aug 4, 2004 | 10:10 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Look in lower right corner of this diagram:
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
